Home > Maintenance & Mods (L322) > Key fob low battery
dpm
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Key fob low battery
My key fob low battery message is on my dash, I'v put a new battery in fob, disconnected car battery, pushed the buttons twice on the fob but still cant clear the message on dash. Any ideas what to try next ?
Post #575450 8th Dec 2020 10:08am
let the FF sleep for a while and the message should clear......
if it doesnt it could be the replacement battery which is at fault ...duracells normally work best.. ... - .- -.
Post #575451 8th Dec 2020 10:16am
mpirie
I found locking the car with the remote and unlocking it again cleared the dash message for me.
Mike
Post #575452 8th Dec 2020 10:35am
dpm
Yep tried both of those, even used the spare key fob which I know was OK last time I used it, but still cant clear message.
Post #575455 8th Dec 2020 10:49am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I had this when i did mine. it just seemed to fix itself after using it a couple of times 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575459 8th Dec 2020 11:16am
dpm
Just an update, bought another new fob battery today, 2032 put in fob and message cleared. Thanks for replies.
Post #575500 8th Dec 2020 5:34pm
Jayk69
i think Duracell are the batteries of choice here. they also give a 10yr guarantee that it will work from the packaging Bow down
that is pretty awesome to say if you un pack after 10 years it will be as good as new 2012 Vogue 4.4 TDV8 - Current
Post #575521 8th Dec 2020 10:40pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Low keyfob battery message
Have the same issue here so will let it sleep and hopefully will clear itself. Useful system but only if it is cleared before next low battery.
Dave
Post #607489 27th Sep 2021 9:28am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I used Energiser ones. They also have a 10 year shelf life guarantee and child resistant packaging.
Duracell have a counterfeiting problem and I've been caught out by it before.
Post #607491 27th Sep 2021 9:44am
Nylands
low battery message
Hi Caesium
Thanks for that. I checked it with a volt meter after cleaning surfaces and it showed 3 volts etc. Also my other key which didn't clear it either. Its rested for a day so will try it again today, fingers crossed!
Smile David
Add on, As has been posted above the message disappeared after a days sleep. Rolling with laughter Rolling with laughter
Post #607494 27th Sep 2021 11:06am
