![]() | Home > Technical (L322) > electrics not shutting down |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
SOUNDS as if it could be, its the right area; do you know if it has a dedicted fuse ??
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
The fan isn't shown separately on the wiring diagrams, I presume it is an integral part of the air temperature sensor.
where is it actually located in the dash ? |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
What model year is your car?
Hiding behind the big red circle on a 2010MY vehicle! ![]() |
mine is 2004 vogue !! |
In that case you may want to have a read through this thread and see if it helps: https://www.fullfatrr.com/forum/topic38061...yni500040k
thanks i will take a look
intersting about hevac fan Which will invesstigate, but feel my fan noise is more passenger footwell area, but just wondering, will car only go sleep with locked doors, or would it still sleep if you just took keys out of ignition ?
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
No need to lock vehicle for it to go to sleep. However, just have to open doors bonnet or boot for things to spring back into life. It's a b"::;r for draining the battery. I can leave my car for 3 or 4 weeks with no problems starting or, if I'm doing any jobs involving multiple entries over the day then I have to make sure charger is connected! Previous cars:
hi martin, yes i imagine every time its 15/20 mins before things shut down again !!
I wouldn't advise snipping the wire to the fan, you'd be masking the symptom rather than fixing the problem.
Pulling Fuse 62 (10amp) in the front fusebox (A/C / HVAC) seems to stop the noise and kill the 0.2amp draw for me.
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
If you place a stamp sized piece of tissue paper over the little grill containing a tiny fan for the HVAC you should find it is held in place by the suction of the fan, when your turn off the engine and lock the car, after approx 15 mins the tissue should fall off indicating the fan has, shut down therefore no suction, if it remains in place then its likely the fan is, still running albeit silently and drawing current.. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
