![]() | Home > Technical (L405) > Burning Rubber Smell |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
touch the wheel after the long journey and see if the wheel is hot..it could be a sticking caliper.. ... - .- -.
| Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931
Burning rubber?....those were the days!!! |
| Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158
Yes, I’ve had it on mine too. I did check all the calipers straight away and they were all cool. I’ve had the same thing on at least one of my late D4’s. It never seems to have caused a problem.
| Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 51
Hi All,
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
I think the DPF regen sounds like a plausible explanation. Kev
Or a leaking engine oil cooler? They leek onto the exhaust and STINK!!! Worth a check |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Leaky oil cooler was my first thoughts...get underneath and see if any oil on rear edge of engine under tray first. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Agree with Dr Rob and Craig, done quite a few of these and they do stink a bit. |
Thanks all I will have a look to see if there are any leaks? |
Only had a quick look this morning, I’ll have more time at the weekend.
Ok so after further investigation, I have a very small leak from the oil cooler gasket 😖 (as you predicted.) currently ordering the recommended seals / gaskets as per other the other threads on the subject.
| All times are GMT |
