Home > Technical (L322) > Locked out with flat battery
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
That’s strange.
It levers upwards then reveals the actual lock on mine.
 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #575873 12th Dec 2020 7:56pm
chris_read
Ok, so the photos didn’t go quite right, but you’ll see what I mean Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #575874 12th Dec 2020 7:56pm
That’s right, it’s on all of them.
Key up and in them pull the bottom of the key towards you away from the door. The hand book pics are a bit off. There is nothing that can't be fixed with a hammer😜😜
Post #575875 12th Dec 2020 8:13pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Mine has a regular keyhole on the offside, but the nearside lock cover doesn’t have the little hole to ease it off, nor does it want to come off with some trim removal tools. And it doesn’t have a little picture of a padlock on it...unless there are aftermarket covers Shocked
Post #575880 12th Dec 2020 8:47pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
12 S socket, center pin earth, pin at 6 o clock (dead center below it) is 12 volt positive live, made my own lead up to charge it through socket.
Post #575888 12th Dec 2020 9:17pm
JoolsB
^^^^^^^ Well, that sorted it.
Knocked up a couple of connectors, inserted as above, albeit mine was slightly offset, it I guessed on the one with all the corrosion on it, hooked up to a charger for a few minutes and...Lo...managed to get in.
From there, just a matter of hooking it up to the Landy for a while and it fired up first time.
Nice long run to get some charge back in it and we’re good to go. Forgotten how nice it is to drive after 10 weeks in a Toyota in Abu.
It’s still got a JLR battery though, must be original as I can’t believe anyone would stick in an OEM battery as a replacement. I think I’ll change it, any suggestions? Got a nice yausa 100 ah for the Landy the other day for just over 100
Thanks everyone for all your assistance and especially Richard, who hunted round for a wiring solution for me.
If anyone is in any doubt on the 7pin (white cap) then earth to centre and the positive to the one that would be directly below if it’s on straight.
Cheers
Jools
Post #576008 13th Dec 2020 6:33pm
Baltic Blue
Sorry if this picture is too late, but might help others in future.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #576014 13th Dec 2020 7:55pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Sorry i might be a little dumb here!!
but if i rig up a plug on pins 3 & 4 i can charge my battery from it? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #578783 7th Jan 2021 10:53am
Baltic Blue
Yes that would work fine, but if you look in the ste shop (in the banner at the top of the home page) you will see one for sale ready made.
Post #578789 7th Jan 2021 11:15am
Jayk69
Sadly not for my Ring smart charger!! but hey it will not take much to make that up and a cheap option too i can make the cable as long as i require. 2012 Vogue 4.4 TDV8 - Current
Post #578846 7th Jan 2021 3:30pm
Sam
The below may come in handy for anyone faced with being locked out of their RR with a flat battery.
Had the same problem with mine, completely dead battery that wouldn't even unlock the car. Same thing, everyone said remove the trim on the passenger door and there's the key hole. No, there wasn't. Had all sorts of suggestions ranging from attaching leads to the starter to somehow back feeding through the number plate lamps(!). Anyway, none of the more sensible suggestions worked, and mine didn't have a towbar so that wasn't an option either.
As a last resort I wondered if there was another way.... There is, and it turns out to be the easiest and simplest way to overcome this problem; jack up the o/s/f (No need to remove the wheel), pull down the front section of the wheel arch liner and then reach up through the inner wing area, grab hold of the bonnet release cable near the back of the headlight and give it a yank. You still won't be able to get in to the car but you'll at least be able to charge the battery and then unlock it with the remote.
Post #578865 7th Jan 2021 4:38pm
Baltic Blue
Jayk69,
If you are making up a lead, it is just as easy to put 6mm connectors on the car end and connect directly to the battery feed in the rear fuse box and a convenient 6mm stud for the earth connection.
You will find that the lead easily passes out in the lower corner of the lower tailgate, then you can connect to your charger.
I have on made up and permanently connected on mine with a Ctek socket on th other end.
Post #578867 7th Jan 2021 4:51pm
