![]() | Home > Technical (L322) > Fixed - Multiple lights and faults on the way home |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
I have a modern booster and it did nothing. I’m probably finding out why the car was sold. |
I returned the battery to Halfords, got a refund, drove to JLR and got an original. it was more expensive and the car is listed as needing the AGM. The car now starts and I'm only left with an engine light. Hopefully I can clear that tomorrow with a simple reset tool |
So none of the messages displayed until I tried to drive the car. I’m hopefully going to be able to try a reset tool tomorrow. But there is something strange going on....
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Don't know about the other aspects but, in relation to the steering becoming heavy, did you do the lock to lock with the engine running after reconnecting the battery? John
Yep the steering was light until the errors appeared. The car also became difficult to pull forwards like the gear was hard to engage.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Gr4h4m so sorry to hear your woes.
I have an l322 4.4 tdv8. I feel it could be something that isn’t an easy fix. I will try the rest tomorrow, and try and get to a specialist. That is probably be in the new year before I can get it to someone. |
have you checked the rear where all the media is? i know on the early models that could fill up with water and cause all sorts of issues? worth a quick look. also check where the tow bar goes some people fit a second battery in that space make sure there is not another battery on board you do not know about. 2012 Vogue 4.4 TDV8 - Current
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 298 ![]() ![]() ![]() |
Try Landranger Deeside. They look after my defender but are all over Rangies too. |
Well its on its way to a local specialist, via the back of an AA van. They are going to look at it and get back to me. I have also contacted ecutesting.com to see if they can fix the unit in case it is faulty as they seem ridiculously expensive as a new part!.
So the garage think it was a bad connection to the abs module, I’m not convinced just unplugging the thing is a fix as I had already done the same. I have contacted the ecu repaire site but they haven’t seen the exact module part number before. Does anyone have any other contacts that test abs repair the abs modules? |
I thought I might close this thread. The garage cant find a fault now as they have wiggled the connector on an off and the fault has gone away. If the part wasn't over £2K I would change but I have no assurance it will fix the issue. The specialist has only managed to do the same as I can on the drive.
So after picking my toys up and putting them back in the pram I managed to find someone that will fix the LR020484 abs module. Most places have said no to it, they are trade only so I need to speak to my local place and ask them to take thw unit out a s send it off for checking/repair and then re-fit, brake bleed etc.
