Home > Technical (L322) > Help! Starting problem - gear lever??
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Had a couple of times where my car wouldn't start/ wouldn't even turn over. I'm going to Devon on holiday in it on Monday so need to sort it sharpish.
Here's what it does. Turn the key to start the car you just get a faint kind of clicking/ whirring noise coming from under the gear knob.
I tried for 10 minutes to start it earlier and ended up pulling the plastics off and tapping around where I thought the noise was coming from, then it started.
Has anyone else experienced this? Is there a small widget that has to engage ( to tell the car it's in park for example) before it will start? The battery and alti are fine, I'm confident (ish) it's not s starter motor issue.
Driving me mad Twisted Evil
Any help would be appreciated My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #57622 30th Mar 2011 5:23pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Have you tried Jump leads / Booster pack when it happens?
My TD6 kept doing that until I put a new battery on
Post #57627 30th Mar 2011 5:36pm
hoppy_70
Did you get the clicking under the gear lever?
I didn't try jump leads but then when it does start it starts with gusto. Plus the batt was tested about 2 weeks ago. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #57628 30th Mar 2011 5:42pm
hoppy, i'm sure i read somewhere that theres something under the gear stick console that gets stuck or fails... ... - .- -.
Post #57634 30th Mar 2011 5:54pm
hoppy_70
That sounds like my problem stan, I can't find it on here though?
I AM officially rubbish at searching though...
Lee. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #57635 30th Mar 2011 5:56pm
i tried a search as well ,couldnt find it either ,hopefully someone with memory of this will advise.. ... - .- -.
Post #57637 30th Mar 2011 6:00pm
found this but its not exactly like your problem but it might help...
http://rangerovers.net/forum/viewtopic.php?t=42173 ... - .- -.
Post #57642 30th Mar 2011 6:10pm
hoppy_70
Just been and had it apart again. I thought it might have been the brass looking motor type thingy, but I think that's the locking mechanism that keeps it in park till you press the brake. I couldn't get it to replicate the fault (typical) so will have to wait till it goes again before I can look closer.
The other post you put up said it all needed lubricating, that may be the case here Rolling Eyes My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #57645 30th Mar 2011 6:47pm
lets hope its a one off LEE.. Thumbs Up ... - .- -.
Post #57647 30th Mar 2011 7:02pm
hoppy_70
I'm not that lucky! Plus, it's a 3 off already Laughing My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #57664 30th Mar 2011 7:52pm
