Home > Maintenance & Mods (L405) > Clips for side Fins
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Clips for side Fins
Hi. Can anyone advise the part no for the little white panel clips that often need to be replaced when changing the side fins ? Also the tape used if possible although I suspect this is the best that can be found and non LR. Many thanks. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #576277 15th Dec 2020 7:45pm
Can't help with the clips - I managed to salvage enough between the old & new (used) set I had.
For tape, I just bought some No More Nails tape from B&Q - not sure they are ever coming off again though Whistle
Post #576283 15th Dec 2020 8:45pm
CMJ
Turns out for the white style clips it is LR117109 if anyone needs in the future 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #576496 18th Dec 2020 8:28am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
If you search Aliexpress you can get a bag with hundred assorted clips for the same price as one clip from Land Rover. These are consumables that you need in the garage anyway. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #576574 19th Dec 2020 8:44am
