![]() | Home > Technical (L405) > Garage door opener |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367
If your garage has a secure rolling code remote then you won't pair it to the car. The only way you'll get it to work is to downgrade the security of your garage and fit an aftermarket receiver that uses fixed code.
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1125
Mine are voice activated, I say get out and open the gate and she does as she is told. |
| goddo Member Since: 27 Oct 2020 Location: south Posts: 84
A much braver man than me, Dixy!!! |
| Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096
If I tried that I’d get some negative feedback....... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
I just gaffer taped a remote to the ceiling of my D4 so I don’t have to fish about for it when I want to drive in....
| ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288
I’ve spent more hours getting to a solution that works than I’d care to confess (I just hate giving up!).
This almost sounds as if there is a generic problem with the way LR set this up then?
It’s just “purchased in” old tech which hasn’t been able to keep up with all the different gate and door manufacturers different systems at the same time. Arguably it’s pretty much the only solution out there which works with multiple manufacturers.
| All times are GMT |
