![]() | Home > Technical (L322) > Battery or charging issue? |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Had a similar issue and it was the carbon brushes on my alternator. One was only just touching hence low voltages and battery going flat despite 100 mile round trips . The car is 18 years old though so was not totally unexpected |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
What is your charging voltage at idle and 2500rpm with load? If it starts at 13.5v or lower then rises with revs your alternator is on its way out... also the alternator can cause a large drain if the rectification circuit fails.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Thanks, will try to get a better test as well. It had a new alternator 15k miles ago so hopefully not that! Here is a video I took a couple weeks ago. It’s at idle for the first 13 seconds then the engine is shut off (ignore the rpm at the top, not sure why it shows incorrectly). Rear calliper decided to seize this morning so that’s another thing on the list
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
On a TDV8 4.4 2010MY I don't think this is the case. During the first 20 minutes of driving, the alternator sometimes doesn't even charge, only when the car's coasting or at idle will it charge. Once the engine's fully warmed then you'll start to see 14.7v or so, depending on the outside temperature. There's another thread on here recently with more details/explanation... |
Have you tried putting a multimeter onto the battery to see if it marries up with what the IIDTool is reporting? It could be the voltage sensor isn't reading correctly or there's a bad earth or similar giving you misleading readings? :\ |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
My experience as well, until i had enough and exchanged it. But then the second Yuasa did it as well, I refused another exchange and got my money back. Bought a Bosch and had no more issues. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Caution to the OP.
Good call, checked today and all showing correctly.
Interesting - thanks for the feedback [quote="northernmonkeyjones”] Caution to the OP. The later 322s came with an AGM battery fitted. so a lead acid Yuasa will be unsuitable. the charging system works at different voltages than a standard battery and the car has a charge monitoring system, which won’t like a Lead acid being chucked in. [/quote] This one is an AGM I think mate - went for one specifically based on feedback here. Will try a Halfords battery test as the next move. 1995 4.6 v8, green/tan (long gone) 2005 4.8iS X5, blue/black 2011 4.4 tdv8, black/black (gone) 2003 3.0d X5, Oxford green/black/manual 2021 p575 SVR, BR green/vintage tan |
Worth a try - I know the IID Tool reports something like 12.2v for me when I see 12.5 or above across the batteries terminals.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
and don't rely on voltmeters!
??? So how is one supposed to read voltage if one can’t rely on a volt meter |
Man who has a watch, knows what time it is.
When I’m in my kitchen I have no idea what time it is at all......
Hehehehe very good. |
