Home > Technical (L322) > Sudden heavy stearing |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1343 |
My 2004 4.4 got heavy steering when the power steering pump was failing, but not so on/off. But tight lower speed turns would be where one would notice it most.
18th Dec 2020 1:29pm |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 |
This happened on my Jaguar when battery was low, not sure if it's applicable to the RR. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
18th Dec 2020 1:32pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 841 |
Yes if that battery is low it happens on the range rover mine did it a couple of times before I swopped out the battery |
18th Dec 2020 2:03pm |
Oddvar.L Member Since: 22 Aug 2020 Location: Nordland Posts: 34 |
Thank You all for response. Tyre pressure ok.
18th Dec 2020 3:26pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1124 |
Presume you've checked the power steering fluid level? |
18th Dec 2020 3:39pm |
Jupp🙂 |
18th Dec 2020 4:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
failing servotronic valve or bcm, loads re those on the forum... ... - .- -.
18th Dec 2020 6:30pm |
Thanx🙂👍 |
18th Dec 2020 8:22pm |
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 |
There is a wire connection that can break on the Valve - was resoldered when it happenned to me & been fine for 5 yrs |
21st Dec 2020 10:21pm |
My wife said there came a message in the info senter in the speedo, but unfortinally, she's not that used to reading English, and she was rather stressed trying to get thru the roandaboat not hitting the curbs.
22nd Dec 2020 1:08am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
my car had a similar problem which was caused by a failing alternator!
22nd Dec 2020 12:05pm |
Ok, I have noticed the alternator do take some time after startup, before charging correctly. Dont know if thats a bad sign🤔 |
23rd Dec 2020 10:13am |
