Home > Maintenance & Mods (L405) > 5th Service Issues Found
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Just had my fifth service done (80k mikes equivalent). My car was built in 2017 but has covered 72k miles now (all motorway miles) and is well looked after. The service all went well but the inspection report raised a couple of issues that I wondered whether were common or indeed something I should be concerned about.
Engine
N/S rocker cover starting to leak oil
O/S rocker cover gasket leaking oil
Steering & Suspension - Front
front castor arm bushes perished and starting to split has movement in bush
movement in front anti role bar bushes
I was surprised about the rocker cover gaskets and figured it was a bit early for bushes to go? Grateful for any thoughts from my learned forum colleagues! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #576700 20th Dec 2020 3:25pm
Wow! Is yours a pig to drive? ie, does the front bang about from the bushes & ARB?
I would look at a second opinion personally, put her into another MD, and ask for a health check... Thumbs Up
Post #576703 20th Dec 2020 3:35pm
Jase71
Hi Craig,not at all mate. Smooth as a peach. I was surprised!
Maybe trying to get me to upgrade? Whistle 2017 Range Rover Vogue V6 Diesel
Post #576707 20th Dec 2020 3:56pm
i had the same year service on my tdv6 in november and i had no advisories like you have..
for comparison ,mines a 16my with 65k miles.. ... - .- -.
Post #576715 20th Dec 2020 4:27pm
AnotherMutley
At the 3 year service on my D4, the garage highlighted that both rocker covers were leaking and said that it was common on the V6 Diesels, fortunately it was done under goodwill from LR as the warranty had ended.
Post #576721 20th Dec 2020 5:03pm
Jase71
My warranty ended in apr 20. I think I’ll get a second opinion though.. 2017 Range Rover Vogue V6 Diesel
Post #576725 20th Dec 2020 5:29pm
goddo
From previous experience with LR, and other brands to be fair, garages are just looking for work and it varies between this sort of thing across the board to discs and pads wear, brake hoses splitting/pipes corroded.
Second opinion advised.
Post #576727 20th Dec 2020 5:40pm
Jase71
I think so. With a 3 year old car I can’t see these issues occurring without a manufacturing flaw/defect. 2017 Range Rover Vogue V6 Diesel
Post #576732 20th Dec 2020 6:01pm
Jase71
At £2,300 for both the rocker cover gaskets you could say I also wasn’t keen Shocked
I remember replacing them on my old MG TC in about 10 mins.. Laughing 2017 Range Rover Vogue V6 Diesel
Post #576734 20th Dec 2020 6:11pm
knwatkins
I'm with Craig and would recommend getting a second opinion. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #576740 20th Dec 2020 7:18pm
Jase, if you have free time i would suggest taking yours to Craig..its a couple of hours journey and you'll get a honest report .. ... - .- -.
Post #576747 20th Dec 2020 8:39pm
Jase71
Sounds like a plan guys. Will have to wait to get out of Tier 4! 2017 Range Rover Vogue V6 Diesel
Post #576750 20th Dec 2020 8:57pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Maybe they put accidentally cork based ones in your car Razz Just like your MG may have had, or my daughter's Golf MK2 GTI definitely had...As you say, an easy job once a few bits are out of the way.
Bushes sound a bit early, wouldn't need a second opinion though, one can easily inspect yourself Wink And even more importantly notice how it drives if in tune with the car.
Post #576774 21st Dec 2020 7:26am
Really bushes are mileage dependant rather than age dependant. 72k of motorway miles may see some of them on the edge. It’s a fair old whack for a 3 year old car, but it’s still a heavy car which is at the point where they “could”require doing especially if there has been some potholey country lanes thrown in.... There is nothing that can't be fixed with a hammer😜😜
Post #576813 21st Dec 2020 12:45pm
goddo
OP does say it's all motorway mileage so it does seem a bit premature for these bushes to fail.
Post #576814 21st Dec 2020 12:48pm
