![]() | Home > Technical (L322) > Ticking noise form rear part of engine bay |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
Mine does this, not as deep a sound as yours, mines a lighter/higher “tick tick” metallic noise from the rear of the engine, drivers side (RHD) and low down, not near the top at all.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
It could be a hydraulic lifter. The only way to definately know is to get the heads off. Kev
maxg67 Member Since: 10 Jan 2020 Location: Verbania Posts: 12 ![]() ![]() |
Not temp dependent, since starting to stop, keeps ticking the same way, perhaps litter louder at very cold start but for few second, then constant and related to rpm, like something moving with shaft or related. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Could be a failing injector, which has got a bit noisier, or as said one of the lifters with a bit of slack.
I would exclude the injectors, since were just overhauled and adjusted (twice, after the high pressure pump failed sending metal filings all over the fuel system), in addition the engine runs well, without hesitation.
