Home > Off Topic > Sit on Grass cutters |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3055 |
Get a robomower- I did and it’s perfect. Does its thing in peace and solitude. And lawn looks good every day, not just the few days after I’ve cut it. |
19th Dec 2020 7:57pm |
I’ve got an old mountfield front deck mower. It’s old but works brilliantly, much much more manoeuvrable than a tractor.
19th Dec 2020 8:58pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Bill
19th Dec 2020 9:52pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 541 |
You don't say how big an area you need to cut...
20th Dec 2020 1:31am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
John Deere might be worth a look the whole range is quite reasonably priced. I've had mine 3 years now and it's never missed a beat, massive improvement from all of the previous ones I've had.
20th Dec 2020 3:58pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Agree about John Deere but another marque is Gianni Ferrari. The 200Tg is diesel and would fit the bill. John
20th Dec 2020 4:27pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 525 |
Another major consideration is whether you have slopes or flat land. If flat then anything will work and you will be able to get a better finish with some finer rotaries or even cylinder gang. I used to have a zero turn Kubota with a 4ft deck and collector which was great for the lawns, around flower beds etc but rubbish on slopes. And we have lots of slopes so it gets more tricky - eg the Stiga Park Pro we trialed despite being 4WD was unstable on turns at the bottom and struggled for traction up hill, whereas it was really good on the flat. For the last decade we've had an Aebi Terracut TC7 with 4ft triple rotary for the bits closer to the house - and that can be used up to about 40 degrees. I used to have a Kubota tractor with 6ft Muthing flail for the bigger bits further way from the house but that got written off so I replaced it with a BCS (same flail). BCS, Ferrari and Pasquali are all the same "alpine" tractors, all made in the same factory just depends what colour you like - BCS/Blue, Ferrari/Green, Pasquali/Yellow. They are very good on slopes if not quite as good as the Aebi and you can get normal steer or articulated if you need tighter turns - Normal steer better on slopes. While the Kubota was fantastic as a tractor, the BCS is comparatively "agricultural" and the 56hp diesel puts out a lot of black smog - but it is much more stable on slopes. They're all daft money though - just looking at what you actually get compared to a car etc. Mike - MPx
20th Dec 2020 6:21pm |
Johnh Member Since: 08 Nov 2011 Location: Rugby Posts: 43 |
It depends on size to mow, finish required and how many trees, bushes, etc get in the way. I have a simplicity regent 40" cut, which can collect, not collect or mulch.
20th Dec 2020 9:41pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2971 |
We bought a John Deere 455 with a 54” deck and a 346T collector on the back of it in 2004. Other then changing the collector for an MCS560 last year, we’ve not had to do anything other then routing servicing. It’s been a fantastic machine and I’d have another in a heartbeat if anything ever happened to this one.
21st Dec 2020 12:08am |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1165 |
Thanks everyone
25th Dec 2020 12:56am |
