Home > Technical (L405) > Possible DPF issues.. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Back to independent to read codes. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Dec 2020 8:38pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
agree with Dr Rob
25th Dec 2020 8:51pm |
If you've only just bought it then I'd reject it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Dec 2020 8:58pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 954 |
It’s a V6, perhaps an oil dilution issue? It’s a known problem |
26th Dec 2020 12:46pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Sounds like an ideal candidate to return it to where you bought it and walk away! |
26th Dec 2020 2:53pm |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 214 |
Do you do short journeys?
26th Dec 2020 6:49pm |
One post and.....gone! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Dec 2020 7:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34944 |
might be still recovering from to much sherry on xmas day... ... - .- -.
26th Dec 2020 7:47pm |
numagoo Member Since: 25 Dec 2020 Location: Manchester Posts: 5 |
Wow give a guy a chance... Just driven 270 miles with a full DPF warning and car in restricted power mode (had no choice) had to get to where i was going. Seems to me like the car isn't doing its passive regeneration ! |
26th Dec 2020 8:34pm |
I do quite allot of motorway driving and backwards and forwards between Manchester and Devon.. No option to return the car unfortunately. |
26th Dec 2020 8:37pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3065 |
Right, I will give you the benefit of my experience to date (2011 TDV8). Any of these may be relevant or not.
26th Dec 2020 9:56pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 326 |
Great post Dolphinboy, very interesting! Having a reference point for those values is super useful, ta! |
27th Dec 2020 1:54am |
Sorry, please accept my apologies I recommended T&S Norman in Somerset to Dolphinboy who found the thermostat fault. The thermostat issue has added to the body of knowledge on here Take it there if you can maybe...? High pressure smoke test is a must. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
27th Dec 2020 9:46am |
Dolphinboy many thanks for your detailed post.. i will be on with your suggestions!
27th Dec 2020 1:04pm |
