Home > In Car Electronics (L322) > DAB no signal
OO__OO
DAB no signal
My radio does not pick up any signal for the DAB radio. VHF radio & dual view TV work fine, haven't tried the SAT NAV as I never use it (well out of date!) though the maps work ok.
I've tried searching but cannot find this particular fault.
Any ideas how to test the aerial or amplifier?
It's a 2011 Vogue SE TDV8. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Lightweight L/R I converted to Ford 3.0 V6
Classic RR 2 door with 200TDi - written off!
Classic RR 4 door V8 - changed to 200TDi from above
Lada Niva - Little off-road toy
Disco 300 TDi Auto - Thirsty
Classic RR Overfinch 5.7 - Very thirsty
Disco II TD5 with off road kit
Grand Cherokee 4.0
2002 L322 4.4 V8 on LPG
2011 L322 4.4TDV8 SE
1943 Ford GPW
Post #577550 28th Dec 2020 8:08pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I assume you have tried an auto retune?
I often have to retune mine.
Post #577553 28th Dec 2020 8:24pm
OO__OO
Yes, tried rescanning but no signal so will not receive anything. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Grand Cherokee 4.0
1943 Ford GPW
Post #577565 28th Dec 2020 9:53pm
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
Have you installed a dash cam by any chance?
Post #577568 28th Dec 2020 10:25pm
OO__OO
Hmmm, yes I do. I had a problem with my 2002 Rangie with very poor VHF reception caused by a dashcam in the rear window.
I have tried unplugging the dashcam (front screen, none in the back) but no difference unfortunately. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Grand Cherokee 4.0
1943 Ford GPW
Post #577585 28th Dec 2020 11:18pm
basil
There is a well known issue with cabling (esp Dashcam) following the same path as DAB cabling - it kills the signal. Only way to prove this is to remove the dashcam cable - Power off will still leave the ability fo the cable to coal up the nearby signal.
Post #577588 28th Dec 2020 11:22pm
OO__OO
I've disconnected the power to the dashcam at source, a USB power supply which I unplugged. It is just a 5v supply & runs up the drivers front pillar to top of the screen, not near the DAB aerial lead I don't think.
I've checked the power supply to the aerial amp & it is ok, 12v. Austin Champ - First car I owned in 1967 ETE167F
Willys Jeep
Grand Cherokee 4.0
1943 Ford GPW
Post #577692 29th Dec 2020 6:59pm
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Did you get to the bottom of this? No DAB on mine either!
Post #579639 13th Jan 2021 7:30pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
My dashcam wiring goes along the windscreen under the headlining, down the passenger a-pillar and into the fusebox behind the glovebox. The cable for the rear camera goes along the headlining and along the drivers side of the car and I have no issues with my DAB reception.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #579645 13th Jan 2021 8:13pm
Bluespanner
So to add a little intrigue, my battery was flat this morning. My fault as I’d left it unlocked for 4 days so it hasn’t shut down properly. Jump started it off the defender and DAB worked perfectly! However it then started to crackle out and now we’re back with no signal. So I’m wondering if it’s a voltage problem somewhere along the line
Post #580634 21st Jan 2021 12:19pm
MuddyTDi
Any updates on this? I have the same issue on a 2011 TDV8 Vogue
TV and radio work fine, I can select and have tried all the different DAB channels and set to United kingdom but it won't pick any signal up even when searching.
No dash cam or anything. can anyone confirm what the DAB module looks like I can't easily see a module in the rear left.
Post #652852 7th Jan 2023 1:59pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Watching with interest, as I'm sure the DAB in my 2011 5.0 S/C used to be 100% solid anywhere, and has become a bit patchy/selective in the last year or so, but I thought maybe it was just me!
Post #652923 8th Jan 2023 12:00am
mrtomyard
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Anyone had any joy with this? DAB has packed up completely today… no reception, won’t auto tune and no idea where to start looking Laughing 2011 TDV8 2011 Vogue 4.4 TDV8
2009 D4 HSE
2003 Freelander
2001 D2 TD5
1963 Series 2a 109 Truck Cab
Post #657162 19th Feb 2023 9:34pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Same for me, used to work perfectly and now have no signal
Post #660761 31st Mar 2023 12:43pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
I doubt that your battery problem comes from not locking yor car, I never lock my car in my garage, even when I am on vacation for 2 weeks and my battery has never been flat.
Maybe this is related to the DAB problem? DAB sucks battery or weak battery no reception?
Post #660783 31st Mar 2023 2:31pm
