![]() | Home > Maintenance & Mods (L322) > Is this battery ok for 2011 TDV8? |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
need to change battery soon. going for AGM (original is LR). Is this a simple swap? seems like a good price?
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
I’d look at this:
| QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 57
I have had the Yuasa 019 in my 2011 Tdv8 for 2 years & have had no issues, it has stood for 4-5 weeks started up no probs. Yes I know it’s not an AGM, did battery change procedure with gap tool. Has 3 yrs warranty to go! |
| 4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185
Over Christmas I replaced a 2 year old Yuasa 5000 battery on my 4.4 TDV8, due to the battery not holding sufficient charge during the cold spell, causing all sorts of error messages.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
These guys are pretty good:
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Current battery LR are supplying is an Exide AGM 019.
| Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322
I agree. Yuasa on paper has higher specs, but it doesn’t seem to be like that in actual usage.
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
After reading the recommendations on here I opted for the following battery
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
Re the Exide AGM mentioned by the OP, short answer is yes it will fit and work fine.
| neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79
Std battery for the LR, as supplied by LR dealers is an EXIDE.
| All times are GMT |
