Home > Technical (L322) > 2011 4.4 TDV8 Battery voltage
Dstew
Hi everyone. Just bought my first FFRR and have a battery question. Sitting on the drive the battery shows around 12 volts which I assumed to be on the low side. Alternator charging at 14.7 volts so no problems there. Is a new battery recommended? Tried the FBH while parked and it seems to go through a start up cycle but then stops and the battery showed only 11.4 volts.
Thanks in advance for your help.
Regards
David
Post #577615 29th Dec 2020 9:14am
Dolphinboy
yep new battery required. My 2011 is exactly the same. 12 v resting. Not enough to get the FBH going, which was (until the cold weather!) working fine. you may also start get "battery Low - start engine from time to time.
Post #577618 29th Dec 2020 9:30am
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Exactly the same on mine, then I fitted a nice new LR Battery, as mentioned in the battery changing thread.
Finally had a great working FBH.
Cheers
Post #577667 29th Dec 2020 2:57pm
Dstew
I had a quick look under the bonnet and this is what has been fitted.
Post #577674 29th Dec 2020 4:17pm
neilly
Yeah, that aint right.
This is what I have
Cheers
Post #577675 29th Dec 2020 4:20pm
DrRob
Should be 850 minimum Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #577679 29th Dec 2020 4:48pm
Dstew
So it seems. Not sure which muppet in the past thought a Fiat Ducato battery was a good idea. Not even AGM.
Think it will be a Varta G14 for me.
Post #577686 29th Dec 2020 5:23pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
You don’t say what model year you have ......
If AGM battery, then you will need to reset the battery management ECU when you make the switch
Post #577800 30th Dec 2020 4:58pm
Dstew
In title of first post. 2011
Post #577804 30th Dec 2020 5:18pm
PeteT80
Fitted G14 today bought from Tayna, offer ends tomorrow.
https://www.ebay.co.uk/itm/361883445884
Post #577810 30th Dec 2020 5:56pm
paulwlincs
I've got a Yuasa ybx5019 fitted to my 2011 tdv8 , the battery voltage has always been 12.1v at rest which has always concerned me but it's never been a problem . It was new when I bought the car 2 year's ago I do have it on a ctek 5.0 when it's not used for any length of time .
So my question is do I really need a AGM battery when I do replace it ? 2011 tdv8 4.4 vogue Santorini black
Post #577879 31st Dec 2020 1:56pm
DrRob
Yes, always fit an AGM to later L322. LR swapped them out for AGM for owners for good reason...non AGM are Censored  Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #577886 31st Dec 2020 2:23pm
D3Jon
But you're not comparing like with like. The cranking amps stated on the Fiat battery are measured as EN2 or SAE.
850A EN (as per the LR battery photo) is equal to roughly 720A EN2, so it's not a million miles away from spec...
Might still be goosed though, a battery load tester would give the batteries state of health.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #578066 2nd Jan 2021 9:56am
