![]() | Home > Maintenance & Mods (L322) > Sun Roof Seal |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Looks like it’s been caught on something at some point, or it’s been through the monkey enclosure at a safari park......
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks, Yes I thought it looks like a snag somewhere. Is the Seal replaceable or is it best just to "patch" up? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35757 ![]() ![]() |
i should imagine it would be a lot of work to replace that seal, i would dry it out and glue or put sealant in it... ... - .- -.
Thanks, yes looks a bit of a specialist/expensive job, will sort out when temperature increases! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 91 ![]() ![]() ![]() |
Hi Ricardo,
W, thanks for tip and diagram, very helpful. Will give it a go on a warm day, whenever that will be 🌞 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
A carefully used hairdryer, with a cloth to protect paint etc should get you out of trouble !
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I’ll try that myself as mine has a little lift on the seal too
Yes definitely worth a go. Probably will add bit of sealant too to help ! I've used a mouldable glue called Sugru before to seal things, is very handy stuff. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 259 ![]() ![]() ![]() |
Anyone had any luck sorting this seal? Just noticed mine is exactly the same as Ricardo’s. 2011MY 4.4TDV8 Autobiography Baltic Blue
Been lazy so Actually haven't done mine yet! Got some sugru so will have a go and advise how it goes. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
