![]() | Home > In Car Electronics (L322) > Do all late L322s have TV? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
It’s listed under the standard features, so yours should def have it.
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 ![]() ![]() ![]() |
I can’t seem to find it, my soft key only has DVD, no TV/DVD to toggle between. |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
It's possible that your TV tuner may be faulty or has been bypassed to keep the circuit. What happens when you press the physical Audio/Video button 2011 TDV8 Vogue SE |
It takes me there, from what I can work out I should be able to cycle between tv and dvd |
TV option should be displayed there. If you have the IID Tool check to see if the TV option is showing in the configuration. If not the easiest thing to do is check that you have the TV module installed
Thanks, that’s great. I’ll have a look after work and report back 👍 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
It should have it as Mark says, but tbh, it is pretty in effective and I never used line as it didn’t retain signal when moving (even on the dual view) There is nothing that can't be fixed with a hammer😜😜
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I quite enjoy my TV screen when I'm driven. Had it on all the way back from Cornwall last summer, was perfect. But naturally all depends on the signal strength, I was impressed with how it handed over between transmitters. |
