![]() | Home > Maintenance & Mods (L405) > Topped up AdBlue, still telling me to top up? |
| LT Member Since: 13 Mar 2017 Location: South West Posts: 417
I had the same problem with a 2016 D4. LRA sorted it out with a software update. Important, as it wouldn’t have started if I’d left it. |
| E46ACS Member Since: 23 Sep 2020 Location: Durham Posts: 15
URGH |
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123
What is the capacity, surprised it only took 4 Ltrs. The sensor says it is below X and only resets when absolutely full, its not like a fuel tank. Try filling up again. letters not necessarily in the right order |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
the diesel exhaust fluid [adblue] capacity is 18 litres so you probably havnt filled it up.. ... - .- -.
It seemed to have taken as much as it can, I'll give it another go. 2017 Loire Blue 3.0TDV6 Vogue |
| bear100 Member Since: 22 May 2011 Location: south wales Posts: 204
I have to put mine in quite slow or it will bubble up and over 2010 defender utility
ah, that could of been it. I'll give it a go in the daylight tomorrow. 2017 Loire Blue 3.0TDV6 Vogue |
Yes, airlocks seem to occur every time despite trying my best to fill it up smoothly. That's when parked on level ground. I did hear that if it's parked on an incline, it's even harder to fill up.
| Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158
Its worst of all if you park it on an incline with the back of the car pointing up hill! |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8787
Got a load of the proper screw in bottles off of tinternet, much more than the 10L tubs but much easier to fill.... There is nothing that can't be fixed with a hammer😜😜
I've never topped up this stuff...i believe its a job the dealer does on a service. ... - .- -.
I’m sure they do Stan, but suppose it depends on how far you drive between services.
Mine drains its tank from full in 6,000 miles, so it's less than half way to a service, but it's not far off the current oil change interval |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
According to the doomsayers I may not be able to drive into cities in the future but at least I don't have to worry about this stuff in the present. Geoff |
