Home > Technical (L322) > Alternator or battery? |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Could well be our old friend the engine to chassis earth strap. These are notorious for failing and giving false/erratic readings as they start to break down. Get that checked first, if only to make sure yours is ok as sooner or later it WILL cause a problem. |
7th Jan 2021 7:04pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thank you Sam. Can you tell me where the earth strap is located please? |
7th Jan 2021 7:55pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
Having just replaced my alternator and as I have the scars on my hands and arms to prove it, I hope you don’t have the same issue as me. Mine had developed the classic noise / whine of an alternator which was ready to shuffle off this mortal coil. Can you hear anything similar? 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
7th Jan 2021 8:08pm |
Hi chris_read, no whining from alternator...... |
7th Jan 2021 9:12pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7756 |
Battery connections very much worth checking , but sounds like an alternator to me.
7th Jan 2021 9:14pm |
KG, earth strap is mounted low down on the o/s of the engine, toward the front adjacent to the alternator itself. Could well be the alternator, but as you have to get in there anyway do make sure the strap is sound and tight.
7th Jan 2021 10:28pm |
Thanks again Sam, engine spins over quickly and starts immediately (it was -4 degrees here this morning and it started with ease).....I’ll get the earth strap checked.... |
7th Jan 2021 10:35pm |
Ok in that case the earth is probably good. Worth checking though if you end up having to replace the alternator. |
8th Jan 2021 9:41am |
Had battery checked again by different garage. Battery showing as being ok but in need of charging. Alternator output showed as 12.75 under load. This morning when I started it (without any problems) I got ENGINE SYSTEM FAULT for a few seconds. Engine running fine with no loss of power. Restarted a few times after a short run with no message appearing. Parked it outside for 7 hours (-2 degrees here) same message on start up, switched off then back on, same message....drove for a few miles and restarted a few times with no message appearing....I’m assuming this is related to the low battery....is that a reasonable assumption? |
8th Jan 2021 6:41pm |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 |
It has been bitterly cold and batteries don't like the cold. Went to mine yesterday to find it was below 12v, no load. Recharged to 14+ using this nifty wee charger/maintainer https://www.ringautomotive.com/en/product/RSC806
8th Jan 2021 7:39pm |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 |
After reading quite a few posts on here about flat batteries I bought a NOCO jump starter from Halfords. Yet to test it.
9th Jan 2021 12:15pm |
Thanks for all comments. It’s started without issue, with the exception of Tuesday morning. I’m going to get an auto electrician to check everything over. Don’t want to replace components when not necessary! Didn’t get the ENGINE SYSTEM FAULT message at any point today. I’ll report back...... |
9th Jan 2021 8:43pm |
NJPovey Member Since: 30 Dec 2020 Location: Sussex Posts: 10 |
I've just put a new alternator in my 2006 TD6 with 140,000 miles. I had several weeks of spurious warnings and occasional reluctant starts, then got the faintest flicker of the red light which I thought coincided with driving through puddles so dismissed it initially. No grinding noise, but then the red light came on and stayed on - and every warning imaginable came up as the power drained - just got home as it died! The brushes had completely worn down and the commutator had deep (4mm+) grooves! Hope you get a diagnosis - good luck. |
10th Jan 2021 11:31pm |
Garage charged battery fully today then tested it again...it failed the test! Replacement (under warranty) battery being fitted on Wednesday morning.....hopefully this will resolve the issue! |
11th Jan 2021 6:54pm |
