Home > Maintenance & Mods (L322) > Brakes broken..... brace wallet.... |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 75 |
What a pain. A big more bleeding should sort it. I presume they have the computer to allow the bleeding procedure. |
9th Jan 2021 1:13pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
I’m hoping so.
9th Jan 2021 1:21pm |
Was much better than it was when I started it this morning. Still took it back and the boss said that the high performance brakes can be a pain to bleed, as you have to run diagnostics and 28 pumps per wheel etc, so I was happy they knew the correct bleed procedure. He got in it and said he could see what I meant, so I left it with them again.
11th Jan 2021 5:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Yep, nice to drive something else now and again, reminds you how good the fatty is...
11th Jan 2021 6:23pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1127 |
Does anyone know why you have to put the car in 'bleed mode'? I have the gap tool and I'm fitting new rear calipers tomorrow. |
11th Jan 2021 6:47pm |
I believe it does something with the ABS valves/pump to purge any air out. Might be wrong, and it might do other stuff too.
11th Jan 2021 7:17pm |
11th Jan 2021 7:41pm |
Thanks for the info. I have got it printed out somewhere. |
11th Jan 2021 8:18pm |
