![]() | Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :( |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
For £150, I'll let them have the hassle |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
lol I thought as much, its one of those “just because you can, doesnt mean you should”
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
https://www.ebay.co.uk/itm/10T-Hydraulic-P...SwvEFfcvI~
forgot to mention that if its tight enough that you need a tool to get it apart you will also probly need one to put it back together!
Im not continuing with it anymore mate |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Just to close my promise of pictures of the hub puller a friend and I made...
Looks good - very manly lol |
We’ll the knuckle assembly & shaft is out, but not separated (still !)
I have been asked for some dimensions so hope this helps
Bloomin marvelous
So would have been far easier and cheaper to have bought the correct tool in the first place then sir? 👍 |
well duuuh !!!! |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
I wish I had that a year ago when I replaced all four shafts with new reluctor rings , a pig of a job which I did with a large heavy duty tube and a sledge hammer now I can see a driveshaft boot needing replaced . Do you know if someone has been making this version of puller or is down to taking these measurements and giving it to an engineering shop. I think I could do the reverse refitting tool. |
I believe bigbo and a few others have been making their own pullers with assistance from freinds/engineering shops |
