![]() | Home > Technical (L322) > Steering heavy |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3280
BCU can be swapped without coding. do a search on here. there is lots of info on this. Is one of your rear doors refusing to unlock as well? that's another sign of BCU probs. |
| Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714
BCU (aka BCM and Body Control Unit) sounds like your most likely cause.
| harra123 Member Since: 13 Dec 2020 Location: Nairne Posts: 9
Thank you both you taking the time to reply. Both back doors are working at the moment. I might get another BCM off ebay & try, if it works I can get it coded later, is there anything to be aware of when purchasing another BCU?
It might be worth doing some of the simpler tests before buying a BCM - unless you've got access to a very cheap second hand version.
Hi Pawl, where is the steering transducer please? |
Sorry I meant servotronic valve |
The servotronic valve is on the steering column / drivers side of the steering rack - visible just through the wheel arch, easier with the height set to off-road or better still with the wheel & tyre off. Paul,
Thank you Pawl, I think I have seen that, I thought it was the angle sensor |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Might wanna take it too the garage if your going to do the servotronic valve. See somewhere online apparently if you round the bolt or snap it off its a new steering rack jobbie |
