Home > Maintenance & Mods (L322) > Windscreen Spec for Replacement
Dstew
I have a 2011 SE Vogue 4.4 TDV8 which needs a new windscreen.
How do I find out what type of screen it is? It is heated but not sure about any other options.
Are there any part numbers I should be telling the replacement firm?
Thanks
David
Post #579139 10th Jan 2021 9:00am
rjff
Have a search on here for windscreen repacement and you'll find the points to make sure the correct one is supplied and the problems when fitting to overcome.
Rob at Duckworths should be able to give you the part number and you can make sure it has the relevant markings by looking at this photo. Bottom nearside of screen.
It shows the heated, noisereducing, reflective markings as well as Pilkington and Land Rover marks. If it's to be an insurance replacment make sure the insurer is made aware that you require a direct original replacment and the same applies to the fitting company.
HTH Cheers
Richard
Gap IIDBT
Post #579148 10th Jan 2021 11:22am
Dstew
I've got this. Does it make any sense to anyone?
Post #579155 10th Jan 2021 12:13pm
rjff
A quick web search shows Benson as a Chinese? repacement so your car may well have had a non original replacment at some time in the past. Anything showing in the history if you have one.
As I said in my first post the info on the screens should indicate what is requird for an original dircect replacement. Cheers
Richard
Gap IIDBT
Post #579158 10th Jan 2021 12:24pm
Dstew
Thanks for your help. Sorry to be a complete noob but how to I contact Rob?
Post #579161 10th Jan 2021 12:38pm
Weegie
Robin.Hall@duckworth.co.uk John
GAP iiD BT
Post #579162 10th Jan 2021 12:41pm
DrRob
https://www.fullfatrr.com/forum/topic55003.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #579163 10th Jan 2021 12:42pm
rjff
No problems Dstew.
As Rob says there's Duckworth Rob's contact
If memory serves and I'm happy to be corrected:
A car maunfacturer will put out a tender for the required specification of a (say) windscreen. The accepted tender will then be contracted to manufacture a certain run of that part which will be stamped with the vehicle AND glass manufacturers names (OE). At the end of that run the glass maker can supply the same screen but not use the car makers logo (OEM). At that time any other manufacturer of glass is able to make a replecement which may be of the same or lesser standard (OEE).
Replacement screen price will reflect this.
Resale value of the vehicle may be affected Cheers
Richard
Gap IIDBT
Post #579166 10th Jan 2021 12:44pm
Dstew
Rob has replied and said I need Land Rover part LR039064 but not in stock. How do I cross red that to the correct pilkington number?
Regards
David
Post #579272 11th Jan 2021 10:36am
rjff
Hi David
I'm not sure how to cross reference the LR part with Pilkington. Perhaps a web search may help. These two show available from LRParts, but I don't know about them and haven't used them. Perhaps someone else on here could let us know if they are a reliable source.
This matches your part number from Rob.
https://www.lrparts.net/lr039064-range-rov...wards.html
This is the more expensive climate screen (solar reflective is my guess)
https://www.lrparts.net/lr039063-range-rov...wards.html
I assume that, as Rob would now have your reg no/VIN he has checked the car's build sheet and supplied the number for the non climate screen. Still a fair wack for a non insurance replacement. Shocked
Perhaps have a word with a major windscreen repacemeent compnay or two and see what they fit, trying to get the screen details from them?
If there's anything else I can think of I'll let you know, but come back if you think I can help further. And do let us know how you get on.
Nosey question, is the screen replacement by you or through the insurers? Cheers
Richard
Gap IIDBT
Post #579292 11th Jan 2021 1:07pm
Dstew
Have started the ball rolling with auto glass. Asked for LR or Pilkington. The ten year old on the phone didn't even know what a Range Rover was so they are consulting with the grown ups.
More news when I have it.
David
Post #579294 11th Jan 2021 1:18pm
rjff
"The ten year old on the phone didn't even know what a Range Rover was so they are consulting with the grown ups. "
Rolling with laughter you owe me a new keyboard, this one's got tea all over it!
Folks have had autoglass, some good, a few bad, but they all seem to make sure they insist on the correct screen and get it. For me, they replaced my 7 series screen twice after their initial fiiting caused wind noise, without argument.
good luck Cheers
Richard
Gap IIDBT
Post #579303 11th Jan 2021 2:58pm
Dstew
Sorry about the keyboard. 😃
You seem to have same model as me. A 2011 Vogue SE 4.4 TDV8. Is the picture you posted above your actual screen?
Cheers
Post #579307 11th Jan 2021 3:04pm
rjff
Yep, my screen taken just before I posted it.
I think the icon in what would be the lower right area of the info refers to acoustic and reflective or climate glass. The other, left icon is the heated reference.
HTH Cheers
Richard
Gap IIDBT
Post #579309 11th Jan 2021 3:11pm
Dstew
That makes yours acoustic and heated?
Post #579310 11th Jan 2021 3:16pm
