Home > Maintenance & Mods (L322) > Transmission failure woes
udnyrangerover
United Kingdom 2002 Range Rover HSE 4.4 V8 Epsom Green
Well after around 2k miles pretty trouble free after buying car lis biting me hard
After around 50 yards the trans fail or 3 comes up on dash then the HTC and abs lights on....
. Followd by air suspension inactive and battery light on. Keep going and everything goes off only to flash together or individually . Then again sometime all ok
Any ideas people
Post #579564 13th Jan 2021 11:42am
check the battery and alternator condition first... ... - .- -.
Post #579568 13th Jan 2021 11:52am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Defiantly start with Battery charge it fully then get it tested for dead cells. Dont just test for charge make sure it is still cranking at full power too. check Alternator too make sure it is giving out enough juice to charge the battery.
very common for loads of faults to appear when battery is low or not up to scratch 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #579571 13th Jan 2021 12:19pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Jack is spot on, hadn't used mine for a few days and got all the lights/faults on start up, quick run and they all disappeared after stop/restart. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #579573 13th Jan 2021 12:46pm
udnyrangerover
Will be checking tomorrow...in east Kilbride just now and around 4" snow off putting
Was out last night and on the small journey of roughly 5 mile in town all the usual xmas tree lights etc....AND headlights have a mind of there own switching off and on randomly.
Kinda tired of car already but persevering for now...looking to put it in to garage to change gearbox oil, gearbox filter and oil cooler.
After that will decide what to do with car...do like it
Post #579749 14th Jan 2021 5:19pm
Dolphinboy
Check your earth and also whether the connectors are tight enough on the battery poles. they can work loose (or not be tightened up by mechs) and then you get an intermittent elec supply.
Post #579763 14th Jan 2021 6:22pm
udnyrangerover
Connections good n tight...
Battery spins engine easily even after 2 or 3 days idle, starts easily and quickly. ⁶
Post #579766 14th Jan 2021 6:37pm
udnyrangerover
Well left all lights and cooling fan on for about 25 mns... then tried to start car...spun easily and started immediately.
Think battery ok
Checked battery voltage when engine idling.... shock..voltages between 16.4 and 16.7 volts....oops
So replacement alternator ordered, plus when under that area will be changing water pump and viscous fan as there is play in fan.
Also looking to flushing automatic box, replace box filter, and transmission cooler
Annoyed as staying with mother as she I'll so it will be a garage as no tools with me
Post #579877 15th Jan 2021 4:44pm
