Home > Maintenance & Mods (L405) > Over tightened Wheel lugs
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
OK so went to remove one of the rear wheels and as the title says i cannot budge the locking wheel nut!!
had a 4ft bar on and stopped as worried i will shear it off or break locking nut removal tool. spent over an hour with no joy.
So i am now squirting WD40 down the back of it every couple of hours in hope this will help. I have not applied any heat yet as i do not want to knacker the wheel finish though this is looking like i will have no choice.
Any words of wisdom? Bow down 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #579833 15th Jan 2021 10:53am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
You might be better off with a proper penetrating fluid, WD40 is OK but it was never designed as a penetrating fluid as such. I'd agree not to go to far with trying to get the nut undone, especially as the locking tools tend not to be the strongest. 2011 TDV8 Vogue SE
Post #579834 15th Jan 2021 11:02am
Hot air gun or even hair dyer might work without damaging paint. Thumbs Up
Post #579837 15th Jan 2021 11:29am
Take it down your local tyre shop, they get this all the time and are "usually" very good at getting them off...
Believe it or not a rattle gun is very good at getting them off, if you take it gentle the rattle effect will loosen the bolt, hopefully before the nut or locking key break,.
If it does break they will have some tools to get the rest of the nut off without damage to the wheel...
I do 99.9% of the work on my fatty but there are some things best left to the professionals with their tools and most importantly, their knowledge....
Get it done now while you can still drive it and before you get a flat...
Driving it home with 4 wheel nuts will be fine.
Good Luck Thumbs Up Pete
Post #579838 15th Jan 2021 11:35am
Jayk69
Well a good soaking in WD40 has done the trick and just with a normal breaker bar too.
all i had to do was stand on it this is where my heft comes in handy Thumbs Up Whistle Mr. Green
i still need a new key though!! 2012 Vogue 4.4 TDV8 - Current
Post #579844 15th Jan 2021 1:39pm
Do yourself a favour and throw the lockers in the bin sir... Buy 4 standard nuts and away you go Thumbs Up
Post #579846 15th Jan 2021 2:28pm
Hermes
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Agree with Craig; any thief will laugh at those locking wheel nuts....usually the only person they delay/prevent removing the wheel, is the owner Wink
Cheers
Post #579848 15th Jan 2021 2:34pm
Jayk69
good advice new ones on order Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #579850 15th Jan 2021 2:49pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
After a tragic experience with a Volvo XC60 locker, I always replace them with plain nuts... Fun fact: Range Rover ones cost more than twice than Jaguar's!
Post #579854 15th Jan 2021 2:56pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Yep, having owned a D3 Disco where the locking wheel nut broke and just kept spinning when I was doing a wheel swap I am firmly in the “get rid of them” camp.
It took me 1.5 hours to finally get the locking wheel nut off on my driveway with a garage full of tools. I would have hated to imagine if it was 11 o’clock at night in the freezing rain on a small road on Dartmoor what it would have been like....
The first thing I did when I brought home Sylvia was to replace them with normal wheel nuts.
Jim
Post #579855 15th Jan 2021 2:56pm
knwatkins
^^^ This. There are many examples of the LR OEM lockers failing, resulting in a nightmare to remove and potentially damage to the wheel. Not what you want when you're at the side of the road with a flat.
As per Jim's post above, one of the first jobs I also did on my L405 when I bought it was to remove the lockers and replace all the nuts as some were swollen. Also did the same on my old L320. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #579884 15th Jan 2021 5:39pm
Jayk69
In my case the problem was not the locker it was that some Censored had well over tightened them not just the locker all of them on that wheel. In all my working on cars i have NEVER come across a wheel nut a 5ft bar would not free off it was insane.
Still there off now threads cleaned up and wheel back on torqued to the correct setting.
And yes all the lockers are going ordered a set of wheel nuts today Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #579889 15th Jan 2021 6:11pm
ur20v
A Trap
If you have this problem again try slightly tightening the other four wheel nuts to release some pressure on the tight one.
Also never buzz gun the locking wheel nut, do this one by hand then torque first at 10% less torque than the others, then do the other four wheel nuts to full torque with out going back to the locking wheel nut, always means this one isn’t over tightened which can happen if tightened last.
Lastly, throw the locking wheel nuts in the bin... even if you can’t get the locking wheel nut off, thief’s can... easily and quickly, they are a waste of time and only cause issues. Just run normal wheel nuts all round 👍
Post #579894 15th Jan 2021 7:33pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Great advice, they’re a pain in the bum and get stuck when you least expect them to.
Post #579897 15th Jan 2021 8:00pm
