Home > In Car Electronics (L322) > 2012 L322 Subwoofer part number
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I've blown the Logic 7 (non-HD) sub on my 2012 TDV8.
Looking around, the "long oval" shaped subwoofer speaker has been around since 2005/6 but not only do the part numbers change, they seem to stop (depending on the advert) at 2009 or 2010......for example, PowerfulUK list one 2005-2010 with three part numbers for 2005-2010 vehicles.
Any help would be appreciated- does it matter which year the replacement comes from as long as it's the "elongated oval" shaped sub?
Or can anyone confirm the correct part number for a 2010-12, please?
Thanks in advance.
Post #579983 16th Jan 2021 2:56pm
GGDR
Maybe give Duckworths a try with your VIN.
I believe the HD and the standard subwoofers are different.
. Cheers, Greg
Post #579984 16th Jan 2021 3:03pm
Giantlandyman
Thanks for that. I should have mentioned I had the standard Logic 7 and not the higher power HD version.
Post #580012 16th Jan 2021 5:56pm
For the 2010-12 standard ICE there are two listed...
XQA500090
or
XQA500060
Doesn't give vin numbers from and to though...! Pete
Post #580022 16th Jan 2021 6:29pm
Giantlandyman
Thanks for that, Pete.
Therein lies my conundrum, namely, are both part numbers suitable for the 2010-12? The three part numbers refer to speakers which look the same, situated in housings that are identical with visually identical amp units but are they the same?
If so, why the different part numbers? Odd and frustrating.
Post #580050 16th Jan 2021 9:38pm
Doesn't take too long to get the old one out to have a look at the part number, or, as has been said, ask Rob to search under your vin for you... Thumbs Up Pete
Post #580071 16th Jan 2021 11:46pm
i think both numbers are correct...one number superceded the other... ... - .- -.
Post #580083 17th Jan 2021 9:28am
