|  | Home > Technical (L405) > SDV8 Front Suspension Knocking - LTB00557v8 - Help Needed |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Don’t grease the bush.
|  14th Jan 2021 8:51pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | Thank you. I’ll be swapping them out when I have some warmer weather.
|  15th Jan 2021 5:44pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Might also be worth checking the pipes and fluid levels in the ARC ststem. IIRC the pipes can rust and leak, and aren’t visible as are covered by a plastic shield. There is nothing that can't be fixed with a hammer😜😜
|  17th Jan 2021 1:08pm |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | I did that prior when I got it a year ago. It was just a hair below max so I topped it. But it barely took any. I’m pretty sure I looked again when I changed my brake pads etc. and I think we are good there. But good idea 2014 FF Autobiography 5.0 SC
|  17th Jan 2021 4:58pm |
| Posting Rules
