![]() | Home > Maintenance & Mods (L322) > Locking wheel nuts |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 233 ![]() ![]() ![]() |
Bin the locking wheel nuts completely. I replaced all my wheel nuts with Bearmach ones. All but 3 where swollen.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Did mine with Brit part ones on the D4, same nut. From Lrdirect There is nothing that can't be fixed with a hammer😜😜
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1319 ![]() ![]() ![]() |
Thanks guys. Feel more comfortable having locking wheel nuts to protect my bank busting new tyres though!! Will look at Bearmach ones and Lrdirect. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Just replaced my locking wheel nuts with normal ones today (Festive present to me). The "clever" part was starting to be not so clever that I could not get enough grip to torque on or off. Decided to swap out before one got stuck. .
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6800 ![]() ![]() ![]() |
You’ll feel much less comfortable when you come to remove a locking nut when they start to spin internally and you can’t get them off, usually to the side of the road, when you get a puncture and it’s tipping with rain but each to their own I guess |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Mine are going in the bin main reason is they are crap caused me a massive headache getting them off and the second reason is they provide little or no protection against theft 2012 Vogue 4.4 TDV8 - Current
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Agreed, for an owner a stuck/broken/missing locking wheel nut (key) is a massive pain as you don’t want to mark or damage your wheels or make matters worse.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
I have to agree with the owners advising against the use of Range Rover L322 locking wheel nuts.
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
I agree. I spent long hours stuck in the bush, trying to chisel off a lock nut with a screwdriver and a rock from my Disco.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 771 ![]() ![]() |
I may be wrong but I think that the perception that wheels get regularly nicked is a motoring myth that can cause paranoia, I recently bought an old jag with shabby corroded alloys and old tyres. Previous owner had fitted 3 locking wheel nuts to each wheel, what a pain they were to sort out.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I binned lockers on Day 1. All were rusted and on the edge of failing...
I can't get a standard socket on them but a 12 point one works fine, but even that got stuck when I put new calipers on the other day. I've seen some solid stainless steel ones on tinternet but can't find them now!! 4434 Morrison, have you got the company name you had them from? |
I just had a look for the ones I purchased back in October 2019 and again in August 2020 from a different seller - they are no longer available from either seller.
