![]() | Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED |
Slightly off topic a bit , but tonight while i was sitting in the car park waiting on SWMBO i was |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 ![]() ![]() ![]() |
There is a pretty good Denso PDF doc with instructions for accessing "753" mode.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
will it go up on the 'wiki' ? ... - .- -.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
prior to buying the FFRR i had a VW Touareg, i also had the VCDS diagnostic system for my laptop and with that you could change bytes and bits to alter various settings.
have no problems going through the hack process, everything goes to plan, just when i have finished and go to pull off, the screen goes blank with the safety message and only audio available.
Perform the hack whilst moving? 2008 MY Supercharged
will give it a go...thanks Current: TDV8 (3.6) RRS HSE
gl Member Since: 23 Aug 2010 Location: stockholm Posts: 84 ![]() ![]() ![]() |
does anyone know if this works for the my11? 2011 tdv8 autobiography bournville / Arabic
up in wiki.....thanks to porridge for supplying this.. ... - .- -. Y. O. L. O. . |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
As an addendum, now that I have a 2010MY car I tried this and although the Sat nav hard buttons have moved sides and changed around, the procedure is exactly the same.
Maxmax171 Member Since: 01 Feb 2015 Location: Devon Posts: 9 ![]() ![]() ![]() |
Ok i can get to the hidden menu i then put in 753 press ok and get all the other menus, which one do i change to get TV on the go? or is it supposed to work once ive pressed 753 ok. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Once you've put the 753 code in and pressed OK, the Diagnostic Menu screen will appear.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Would be good if someone made a video and uploaded it to show |
there's this for the RRS which is the same [i think]
