![]() | Home > Maintenance & Mods (L405) > RR SDV8 P0107 fault |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
Sounds like a split inlet manifold or hose. Kev
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 ![]() ![]() ![]() |
Hi thanks for your reply.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Pop the engine cover off and have a look at the 4 small rubber inlet pipes for splits |
Thanks again both !
Just to update, it’s my map sensor at fault.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2687 ![]() ![]() |
The running-on after switch off is often noticed with both the TDV8/SDV8 4.4 and the TDV6/SDV6 3.0 engines when in restricted performance mode. |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
MAP or MAF letters not necessarily in the right order |
MAP sensor. £92 from Land Rover. Things tiny too, you wouldn’t think it could disable a RR ! |
GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 20 ![]() ![]() ![]() |
Just to help others in future. I too have just had a Restricted Performance message on a SDV8. Fault code was P0107-00 MAP sensor. Changed MAP sensor and all good to go. $500+ part in Australia from the dealers but only took 5 minutes to install. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3833 ![]() ![]() ![]() |
They soon get clogged up, but are usually fine if given a good clean and put back in.
Tried to clean it first, but that didn’t work this time |
