![]() | Home > Maintenance & Mods (L405) > L405 Park brake fault (Yellow light) |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
Te He... |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 49 ![]() ![]() ![]() |
Well I’ve had the first failure.....RHS motor has failed and I can’t move the beast..... |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Sounds like a design flaw... I did think it was an odd thing for the main dealer to inspect so closely, they must see them allot! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Great pics
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Does the code read tell you which side? |
bump |
look at those cracks! |
albertocsoares Member Since: 28 Nov 2012 Location: Brazil Posts: 15 ![]() ![]() |
Thank you. I probably have the same problem as when I drive under heavy rain the hand brake light goes on. |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 45 ![]() ![]() ![]() |
I had a few incidents of the parking brake refusing to lock or unlock when wet. Just fitted a new actuator today. Found a replacement on ebay for £74 (new part) which upon arriving looks identical to the the OEM item, just without dealer tax. Fitted and working fine. Will swap the other side over when it’s a little warmer as a precautionary measure.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Do these actuators need coding or are they plug and play? 2017 SDV8 4.4 silicon silver AB
They don’t need coding. Just make sure the cable plug is fully seated when fitting the new unit. There is a small cable that clips in under the plug socket housing which can prevent the plug being fitted correctly. Ask me how I know!
