![]() | Home > Maintenance & Mods (L405) > Under bonnet foam pads |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Same here...was wondering the same. Hopefully someone will know |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
If they're similar to the ones in link they reduce wind noise apparently so guru Craig says. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
My nearside one is saturated and has just split - did anyone ever get LR part numbers? Or should I just get cracking with the glue (I'll need a lot) Geoff |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 235 ![]() ![]() |
Unfortunately they do become saturated over time - I tried spraying mine with silicone spray when they were dry, but that only had a temporary effect |
Thanks guys, I have had a closer look this morning and the problem was the freezing weather. Yes, the pads do get saturated but if they then freeze they stick together and opening the bonnet tears the foam.
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Exactly the same just happened to me yesterday! |
I just dried mine on a radiator, repaired them with a bit of silicon glue stuff and replaced. I also used a bit of cling film on each one to make sure they don’t freeze together.
Binned mine ages ago on my L322. Made no difference to so called noise dampening Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
read your warning post Geoff and regardless i tried to open my bonnet yesterday and guess what.....even while i was trying to open it a little Geoff's voice was nagging not to do it but i did..
did any one go ahead and replace these? if so what was the cost and where from? ... - .- -.
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 139 ![]() ![]() ![]() |
yep I did - £142 from LRdirect - the items are supposedly special order but they were delivered in 2 days
were they difficult to replace ?
Easy enough to replace, as you found they are held place with a combination of clips and double sided tape. Cleaning off the remains of the old tape is the hardest part, a solvent helps but be careful of the paintwork. |
as fifth horseman says
