Home > Technical (L322) > 2012 L322 Blower Motor Replacement Question
Goodluck247
Quick technical question on the replacement of the blower motor on a 2012 L322 Westminster.
I currently have the vehicle in the garage to look at replacing a failed blower motor and have been informed the following...
The motor has seized which in turn has damaged the resistor. The resistor has then cooked part of the loom serving it and will require localised rewiring on the loom. My question is though, surely if the resistor was getting to a stage where its cooking the wiring loom, it would trip a fuse prior to it causing this much damage?
Post #581375 27th Jan 2021 2:10pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I would have thought so yes but the fuse to the resistor is 40amp so quite will take quite a current. The wiring to that resistor is pretty chunky cable though
It is fed from fuse R21 in the boot on the right hand side
Changing the blower motor is an involved job...will link to my recent thread
Post #581376 27th Jan 2021 2:13pm
L19 MUD
https://www.fullfatrr.com/forum/topic58107.html
Post #581377 27th Jan 2021 2:14pm
Goodluck247
I was reading your post the other day.. its very involved
Did you happen to take any photos of the resistor in-situ once the dash was completely taken out?
Post #581380 27th Jan 2021 2:21pm
mpirie
The FSR is down on the offside of the central tunnel so it may not be too visible, even with the dash out.
There is a thread with pictures on removing the fan without disconnecting air con etc that I used when I did mine.
Mike
Post #581458 28th Jan 2021 10:23am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
if its just the connector that you require there's one on eBay (its the same plug as BMW)
https://www.ebay.co.uk/itm/Bmw-e46-final-s...Swh7tZrVeU 2010 VSE [Roger]
Post #581459 28th Jan 2021 10:28am
Goodluck247
Cheers thanks Very Happy
In regards to the heater resistor, is it the same resistor found in the earlier models or did it change when the L322 was facelifted in 2010?
Post #581621 29th Jan 2021 3:08pm
L19 MUD
It is the same part in the 2010 on cars too
Post #581996 1st Feb 2021 2:20pm
