Home > Maintenance & Mods (L322) > Towing electrics
nearlee
Wales
Towing electrics
Hi all,
Since the use of my ffrr is changing, I might as well change the twin towing electrics over to the 13 pin type to match the caravan, rather than currently using adapter.
So question is, can I get a plug n play 13pin to replace the twin thats fitted.
07 tdv8 Remember:- amateurs built the ark
Proffesionals built the titanic
Post #581232 26th Jan 2021 2:23pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
https://www.pfjones.co.uk/land-rover-range...506pf.html
Not cheap I would get a 13 pin socket and rewirejust take it slow and have a diagram to show how wires relocate
https://www.google.co.uk/search?q=13+pin+t...&dpr=2 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #581248 26th Jan 2021 4:09pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I converted mine, took about 40 minutes. Wired a new socket and mounted it on the towbar, ran the new cable into the spare wheel well. The existing cables were cut and spliced onto the new cable, easy to follow from the old wiring colours. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #581278 26th Jan 2021 6:28pm
nearlee
Wales
Cheers guys.
I've got a spare 13 to twin adapter, I can butcher that, never crossed my mind to do that Thumbs Up Remember:- amateurs built the ark
Post #581310 26th Jan 2021 10:02pm
dhallworth
The SC that I've just bought has the twin 7 pin towing sockets on it. I want to convert that to 13 pin as well so have bought a standard 13 pin wiring loom from Rob at Duckworths Land Rover.
If you have the standard 7 pin with the LR ECU in the boot you can simply swap the looms over. They're about 150 quid but are plug and play with zero cutting anywhere.
Post #581364 27th Jan 2021 12:20pm
AJGalaxy2012
£150 pays for a lot of soldering, sleeves and time! BMW i3 Electric Car
Post #581382 27th Jan 2021 2:25pm
dhallworth
It does but there are additional changes to the towing looms as well.
I converted my P38 from twin 7 pin to 13 pin but when doing so it's not possible to make the battery charge. You can power a caravan fridge and do everything else but the 12v battery on the caravan doesn't charge.
I've got a 12v commercial battery on our flat bed trailer to run a winch and we use the caravan as well so I want a conventional wiring system that will enable me to charge the caravan and the trailer batteries without any mucking around Smile
Post #581387 27th Jan 2021 3:41pm
Baltic Blue
Lee,
If you go down the wire splicing route to fit, I can highly recommend these connectors.
They are easy to use, very reliable, and neat .
https://www.ebay.co.uk/itm/400Pcs-Heat-Shr...890.l49292
Cheers
Post #581388 27th Jan 2021 3:50pm
AJGalaxy2012
David.
With all due respect, youve done it wrong, the caravan battery will still charge, all of the signals and supplies are present in the 13 pin electrics as they are with twin 7 pin sockets.
 BMW i3 Electric Car
Post #581391 27th Jan 2021 4:23pm
I agree with Mike on those connectors. Have a box in the garage dead easy to use, have a practice first tho so you can get the temps right before plunging into your car electrics....
And as above, if you do wire it right then the battery will charge on a 13pin setup. I’ve not rewired the car end but I did redo my last caravan from S/N to 13 pin and it charged fine. There is nothing that can't be fixed with a hammer😜😜
Post #581413 27th Jan 2021 7:41pm
Baltic Blue
Lee,
I can lend you a heat gun if you happen to be cycling past one day Rolling with laughter
Post #581415 27th Jan 2021 7:48pm
nearlee
Wales
Cheers Mike , I had seen them advertised but wasn't sure.
Will definitely give them a go.
Also I'm good for a heat gun, but will be calling round for a brew soon Thumbs Up Remember:- amateurs built the ark
Post #581449 28th Jan 2021 8:31am
dhallworth
I had a genuine LR 7N socket on the car so I bought a genuine LR 7S loom and installed it and the pins weren't the same as what you've posted above.
I spent hours researching it at the time, and from memory, now I'm thinking about it, there was a change in the early 2000's (prior to the L322 being available) where the 7S pins changed slightly I'm sure.
I'll dig out what I found later on and will post it.
Post #581492 28th Jan 2021 2:47pm
