![]() | Home > For Sale & Wanted > For Sale: headlights, s/c grille, rear lights..... |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
SHOULD polish out if using a 'machine' - BUT if you can feel them with a fingernail (as bodywork scratch 'test') they will not |
They're plastic so will polish out no problem, if the scores are deep you can wet & dry before cutting and polishing |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
£200 for the back lights. |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I'll have a think and let you know.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
how much for everything ,grille lights sidevents and whatever else you have for the front ....im not so bothered about the rear lights "RANGEISM WILL NOT BE TOLERATED"
slim_sane Member Since: 09 Jan 2011 Location: Kent Posts: 43 ![]() ![]() ![]() |
Pretlove - which grille and side vents are you after super charger or normal ones?? |
normal ones will do i assume the side vents are the ones with 3 blades not 2 "RANGEISM WILL NOT BE TOLERATED"
Yeap, the vents are the 3 blade version.
thats not quite true you will remove 'plastic' that cannot be replaced! if they are very deep then you will have problems again i re-iterate - if they fail the fingernail test then do not buy with bodywork you can build up paint layers to compensate for the deep scratches - with plastic you WILL be left with visible defects Last edited by nick h on 2nd Apr 2011 2:16pm. Edited 1 time in total |
I think I'll hold out for a set that aren't scratched, thanks anyway though. |
They've polished out for those who doubted! |
good for you ![]() obviously shallow scratches which is fair enough - i made my comment advising against deep scratches i did not doubt you but offered advice to potential purchasers - so why did you not remove scratches before offering for sale - rather than having to go through all the 'rigmarole'?? |
Nick the answer was simple - time, don't spend that much of it at home and if I am don't want to be polishing out scratches on a part that is used and up for sale. But having seen the chaos that having scratches caused, I went out of my way to go and clear them up - they really weren't that bad I've had them on the car for ages now and not bothered! No offence mate but other people jumped on the thread selling their own goods and rubbishing these. Just wanted to focus back on the parts rather than get distracted by scratches etc..... but I hear what your saying to, deep scratches are a definitely no no for polishing out. |
fine - don't know who jumped on your thread selling? but well done as you showed they were shallow scratches |
