![]() | Home > Technical (L322) > Heating issues |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
I had exactly the same. Common problem this one you need to change this its buried on the right had side as you look at the engine.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Oh joy. How hard are they too change |
Part ordered so let's see how hard this is to change and if it does the job for me.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 228 ![]() ![]() ![]() |
Three jubilee clips one multi plug and wiggle it out the rubber bush mounts, long arms and lowered suspension helps as well. |
Sounds easy enough. Am I right in thinking it's on the passenger side of the engine bay |
Thats the one. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
But isn't this about interior balance? 2010 3.6tdv8 180k km.
Yes interior balance, the unit has a valve for each side, left and right. |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 129 ![]() ![]() |
did this solve the problem? I have the same issue |
Yep sorted mine. Took all of 30 mins too change. Just invest in a 6mm spanner for cracking the jubilee clips off before unscrewing them |
Ok I have just found what I need to replace but how did you do it? I can barely see it yet alone remove it and replace. Is there a guide somewhere? |
What engine you got |
3.6 tdv8 - managed to take a photo of what I am looking at
