Home > Maintenance & Mods (L405) > 5 year service
5 year service
Does anyone have the service sheet or could you post what else gets done on the 5 year service?
Mine is going in on Monday.
They have said that the diffs and transfer box fluids should be done with that service, which is fine and was in the price. Does the ARC fluid get done as well??
Is there a separate notification for Brake fluid? Or will that get done too? I recall it’s pretty reasonable at the stealer in any case. There is nothing that can't be fixed with a hammer😜😜
Post #581790 30th Jan 2021 6:28pm
MJGH
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Copies of the various service sheets for the L405 are in the WiKi.
I think it is under L405 service sheets or something like that.
Hope this helps.
Post #581797 30th Jan 2021 7:00pm
as above , the sheet are in the wiki..
this snip is what they did to mine on its 60 month/80k service..
Post #581804 30th Jan 2021 7:41pm
I had a look in the wiki.
It would appear that they do the trans case, ARC reservoir, and oil and filter. Only cars with active rear diff get the fluid changed at this point.
I’ve asked them to check, and put it on the list along with brake fluid and front diff.... There is nothing that can't be fixed with a hammer😜😜
Post #581843 30th Jan 2021 11:21pm
