![]() | Home > Off Topic - Other Cars > Mercedes SLK |
| bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 616
My wife quite likes the mk2 model so I have had a little look round and found few major worries, certainly less than we are used to on this forum.
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Looked into getting one last year then COVID . If I remember right timing chain issues on V6 engines can be an issue. They all rust especially the early ones on front wings and rear subframes. I’d look for a post 2004 with the air scarf built into the front seats....you can see the vent holes just below headrests. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
| Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 190
I picked up a 1999 230k last year. There is no shortage of rust, the front wings are pretty shot, but new Merc wings are around £150. The interior is shabby, but again easy and cheap to tidy up. It is great fun to drive, cheap to insure and run. There are a lot around the £4k-£5k mark - dunleycarsales.co.uk tend to have one or two. |
| gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 287
My wife sold hers back in August, it was a 2010 AMG trim, 1.8 supercharged. Lovely car and looked the part. Hers was remapped and it went quite nicely. In our 4 years of owning it all that went wrong was the 3rd brake light which they’re apparently renowned for, it’s a simple trim removal replacement and diy worth £70. It had boot water leaks which again are common. Mercedes say to replace the boot seal at great expense. I found some marine white sealant and sealed the two (yes 2) boot seals together and this seemed to work. Apart from servicing it was turn key reliable. The reason she/we passed it on was it was just so low that it was tiresome getting in/out which wore thin.
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
I’ve got a 2010 v6 which I bought ex demo . Its now got 26k miles on it so pretty clean but can’t say I’ve ever had any love for it. They frequently snap the ends off their front springs 2010 VSE [Roger] |
| Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407
Thanks for the advice chaps |
| LiftedDisco Member Since: 13 Nov 2019 Location: Towcester Posts: 32
We had the later version as the SLC - rejected the first one for a variety of quality issues and then ended up with an ‘upgraded’ version...
| drakes Member Since: 26 Jan 2009 Location: Consett Posts: 375
We have had a 2009 280 V6 for 3 years and put 60k on it with no probs at all. V6 engine issues is between known engine numbers, just Google to find exact numbers and yes as mentioned above check for rust on front wings and rear subframe. Just a personal thing but I think the ride deteriorates quite a lot if you go to 18 or 19 inch rims. It won't replace your FF but in the summer it is much easier to get the roof off. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
| Stacey007 Member Since: 03 Nov 2020 Location: Cheshire Posts: 18
Hello
| All times are GMT |
