Home > Maintenance & Mods (L322) > Rear recovery point mussing
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Whilst looking under the back of the car to work out what tow bar I have (not got the Swan neck part though) I noticed there isn’t a recovery point anywhere that I can see, coming from a Disco 3 where there is a very heavy duty one in the centre behind the electrics cover I can’t believe it won’t have one, could it have been removed when the tow bar was fitted, I was always told never to use the tow bar as a recovery point, if I do need to help anyone whats the option especially as I don’t yet have the detachable swan neck 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #582070 1st Feb 2021 9:27pm
dhallworth
The recovery point on the L322 is removed when the tow bar armature is fitted.
When fitting the Westfalia armature (LR Original) the recovery point is part of the armature. If yours is aftermarket it might not have one.
Post #582077 1st Feb 2021 10:00pm
dhallworth
These are what is fitted if you don’t have a tow bar and are removed when you fit the tow bar.
Here is the genuine armature that you can see the recovery point on.
Here’s what you see from the rear of the car if it’s a genuine tow bar. You can see the recovery point above the drivers side exhaust tip. (Picture taken from google images).
Post #582079 1st Feb 2021 10:04pm
As David says, the towing eye is on a bolt on part
You can see the bits above which are taken off and has the eye on it. If a genuine or Westfalen bar is fitted then the eye is welded to that near the O/S exhaust.
*Best me to it David...* There is nothing that can't be fixed with a hammer😜😜
Post #582080 1st Feb 2021 10:05pm
Furnitureman
Thanks for all the replies it’s a tow trust bar the seller thinks he has found the detachable swan neck so that’s one plus, seems odd they omitted a towing eye 2012 Range Rover Westminster 4.4 TDV8
Post #582095 2nd Feb 2021 7:35am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I have a TowTrust detachable towbar on my 2012 AB and I was offered the 'spare' recovery eyes when I had it fitted.
The irony is that I live fairly close to TowTrust but I ended up going to Rotherham to get mine fitted!
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #582109 2nd Feb 2021 12:01pm
Re: Rear recovery point mussing
I think the tow bar manufactures would say don't use it as a recovery point, purely to save themselves from claims.
I can't see why you can't use it for "normal" recovery as it is bolted to twice as many places as the factory point and is spreading the load much better, anything that damaged the tow bar whilst recovering would have ripped off the original part a long time before...!! Pete
Post #582125 2nd Feb 2021 3:26pm
^ this is a very valid point, and definitely applies to the original, not sure about the tow trust, but the westfalia is a chunky well bolted on piece of kit, it does also have an eye by the swan neck which I have always just used for the breakaway cables, but they also seem well attached and would take a shackle..... There is nothing that can't be fixed with a hammer😜😜
Post #582144 2nd Feb 2021 6:37pm
