Home > Maintenance & Mods (L322) > Scraping sounds
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Scraping sounds
Hi all
It's not something that really bothered me but it's something I want to get sorted at some point but I've always had a scraping sound coming from the rear of the car. It's a 2003 v8, but It mostly happens when I reverse for some reason. Am I right in assuming it's more then likely to be the back plates as it never seems to do it whilst driving forward.
What's the options too sort this? Previous cars I've just lost the back plate if I'm honest and never replaced them
Post #582292 3rd Feb 2021 9:53pm
cass
my guess would be handbrake shoe retaining pin snapped/rusted away - that can give those noises
Post #582375 4th Feb 2021 6:00pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Check for small cars, and, shopping trollies.
These can all make such a sound when a FFRR is reversing!
Best, Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #582401 4th Feb 2021 9:03pm
D3Jon
Seconded, the back plates rust easily and the retaining pins drop into the handbrake drum.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #582404 4th Feb 2021 9:31pm
Bean19844
Deep joy so I'm guessing that's new rear plates and handbrake fitting kit I'll need
Hahahha nice one rich
Post #582406 4th Feb 2021 9:34pm
D3Jon
Possibly, or it could be that you just need to drive forwards 100 yds with the handbrake applied to clear rust from the inside of the drums - give it a go! Thumbs Up
2014 Disco 4 HSE
Post #582411 4th Feb 2021 10:43pm
You have to take the rear hubs off to change the back plates and that is a massive job on a car that age, the driveshaft will be in there for good (just about)
If you need a new back plate (they hold the hand break shoes in place so you can't just cut them off) buy new, they aren't a lot and cut them in two, weld/rivet a lip on one side and make them bolt or rivet back together once fitted... so much easier than removing the hub... You need to look at the old one to decide the best place to cut them in half, I did it on my 2002 and it worked well... Thumbs Up Pete
-Click here for Thread-
Post #582422 5th Feb 2021 1:24am
