Home > General > Trim levels |
dkatwa Member Since: 05 Sep 2012 Location: London UK Posts: 16 |
Hi. I don't own a RR yet but had a stupid question. Is the Westminster trim higher than the Autobiography trim? I have googled it and cannot find the trims listed in order. Cheers |
6th Feb 2021 9:16am |
Great..many thanks for the quick reply jordan0
6th Feb 2021 9:40am |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 918 |
Westminster typically replaces Vogue and Vogue SE on the run outs and the range becomes Westminster and Autobiography. Typically trim is better than Vogue but lower than Vogue SE. |
ilard Member Since: 21 Oct 2012 Location: London Posts: 698 |
Technically, SV Autobiography is the top trim. For L405:
6th Feb 2021 3:37pm |
OP, you are looking for an L322, then I wouldn’t get too hung up on trim level. The higher ones are nicer, but if you find a good Vogue with everything you are after and it’s in better condition and history, then personally I would take that over a slightly shabbier VSE or AB. There is nothing that can't be fixed with a hammer😜😜
6th Feb 2021 3:55pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Agree with NMJ, I’ve been looking long and hard and in the end, gone for a vogue because it was the best car I could find, plenty luxurious enough for me, when I’m not in that, I’m in my defender- it’s like being on a different planet. |
7th Feb 2021 10:10pm |
ash27 Member Since: 23 Jun 2020 Location: Hertfordshire Posts: 44 |
Or get a supercharged I believe they are all Vogue SE spec as default?? 07 4.2 Supercharged
7th Feb 2021 11:23pm |
I seriously considered it, but didn’t see the right one.
8th Feb 2021 12:18am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
These are all Autobiography spec sir NOT VSE |
8th Feb 2021 12:53am |
Ah cool.
8th Feb 2021 2:52pm |
