Home > Technical (L322) > New battery flat - charged 25 hours, instant flat
uzp315
Hi all,
I replaced the battery a couple of weeks back for a 90ah Varta Blue. Alternator is charging the battery as confirmed by RAC.
After using the auxiliary heater, doing lots of short runs, I found yesterday I had a flat battery. I unlocked the car, got in, put the key in and turned it just clicked and went into dead mode instantly upon putting the key in the ignition and turning.
I left the car on CTEK MSX 5.0 for 25 hours. The charger showed the charge process complete and successful this morning.
I turned the key this morning and exactly the same thing happened, completely dead car. No locks, nothing.
Duff battery ?
What kind of drain in the car could drain the entire 25 hours of charge if the battery is OK? This doesn't seem very likely to me.
Post #582559 6th Feb 2021 10:23am
check them battery connections.... ... - .- -.
Post #582563 6th Feb 2021 11:02am
uzp315
After an hour on the phone to ECP, I just went out to remove the battery, and also to put a mutimeter on it. Guess what Stan? As soon as the MM probe touched the +ve terminal I got a spark of life in the car. I then realised, you guess it correctly the +ve connector had come lose. A quick tighten and all is good.
Thanks Stan, you are a star.
Post #582564 6th Feb 2021 11:04am
uzp315
P.S. This is not the first time I have made this school boy error ;0
Post #582565 6th Feb 2021 11:05am
