![]() | Home > Maintenance & Mods (L322) > 'suspension' height difference? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
faulty levelling sensor ?.....dan could check your diagnostics? ... - .- -.
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
thanks Stan not taking the RR tomorrow |
When you get out the car, that front corner will spring up. I believe that in access mode the threshold for height correction requests is increased.
johnatandy Member Since: 26 Feb 2011 Location: Dudley Posts: 34 ![]() ![]() ![]() |
Mine did this on the near side front, had the suspension software updated and he reset the height sensor values, good as new. |
DAN, have you this calibration facility on your rac? ... - .- -.
thanks Dan done as suggested and all is level but why did the rear passenger side rear 'drop' sorry to be thick! |
answer please?
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 ![]() ![]() ![]() |
Nick
electronic glitch maybe.. ... - .- -. Y. O. L. O. . |
So when you lowered the car from outsie the car its fine? If so, when you get out the car the lack of your weight on the osf spring will cause it to raise. This will also slightly raise the NSF and the OSR but the NSR will stay the same. Think of a table with 4 legs - then raise one leg up half an inch. The opposite corner will be lower than the raised leg and the other two will be slightly higher too. Does that make sense? ![]() |
thanks guys |
