![]() | Home > Technical (L405) > Engine oil level |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Yes it is a known issue. Search for member Zebedee who concocted a traditional dip stick
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3863 ![]() ![]() ![]() |
Piston,
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
The engine oil capacity is not 11 litres on the SDV8. It is 9.4 litres.
piston Member Since: 06 Feb 2021 Location: Kent Posts: 18 ![]() ![]() ![]() |
I was hoping that it fits through the sump and not in it! |
Yes I was going to do that when the snow melts. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Nope, is in the sump.....
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Is there any obvious way to check if this mod has been done? |
Yes, just look at the loom connected to the sensor on the sump to see if you have the little bridging loom fitted.
Best me to it. Couldn’t find the thread.... searched for everything!
Many thanks. |
thanks for the info |
Ok
The capacity is 9.4 litres. Apologies for being direct, but how come you decided to put 10 litres in initially?
here it is chief:
