Home > Technical (L322) > fuel tank removal
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
fuel tank removal
are there any posts on this
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #583641 14th Feb 2021 7:10am
Info in the Workshop Manual downloadable from the wiki...
Why do you need to remove it..?? Pete
Post #583726 14th Feb 2021 9:08pm
knares
thanks, i did look in Wiki but couldnt find much RR 2005 4.4 petrol
Post #583769 15th Feb 2021 2:24am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
RAVE has several pages on tank removal. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #583771 15th Feb 2021 6:14am
knares
i have a fuel leak
fuel dripping in front of the right rear wheel, cant see where it coming from RR 2005 4.4 petrol
Post #583787 15th Feb 2021 10:36am
That’s very unusual sir...
I’ve never done it, but if you remove the metal guard underneath it, I’m guessing it will all be obvious and straight forward from there...
Post #583793 15th Feb 2021 10:43am
The fill pipe runs down the front of the right rear wheel arch behind the arch shield, does it drip all the time or just after filling..? Pete
Post #583841 15th Feb 2021 3:05pm
knares
i have had the plastic cover off under the right hand side where the filler pipe goes in to the tank, cant see any thing
i have removed the carpet and other parts to get to the fuel pump, cant see any thing there either
this is the first time i have filled the tank, never noticed it leaking before
i have now done 15km since filling it, it still smells a bit but no drips RR 2005 4.4 petrol
Post #583925 15th Feb 2021 9:40pm
I would guess someone has had one of the two opening in the top of the tank open and not shut them properly, there is a rubber gasket which looks like it can be fitted both ways but in fact has a correct way round. If you totally fill the tank till the pump shuts off the petrol in the pipe will leak out the top of the tank and then petrol will splash out the tank till the level drops..
It's an easy fix... can't see the tank will have a hole they are made of very thick plastic and are very tough... Thumbs Up Pete
Post #583933 15th Feb 2021 9:47pm
knares
haylands i think you are wright
i did remove the carpet and look there, i couldn't see any thing
i have now removed the carpet again
i started to fill the tank with fuel, half a litre at a time and eventually i saw moisture around the fuel pump gasket
hope fully thats it RR 2005 4.4 petrol
Post #584030 16th Feb 2021 3:19pm
The rubber seal is slightly wider one side than the other, the thicker side goes upwards, there is a special tool to undo the retaining ring but a hammer and punch works if you are careful, it is a standard right hand thread... The seal is one of those that you chase around the opening thinking this will never fit, it seems too big, it will settle down and go in eventually, handy if someone else holds the filter assembly
The pump is in the bottom of the tank, the bit you can see is the filter, which should be changed at 100,000 miles... Thumbs Up Pete
Post #584033 16th Feb 2021 3:27pm
knares
haylands, i think you are wright RR 2005 4.4 petrol
Post #584036 16th Feb 2021 3:32pm
knares
three times i have tried to post and it would not let me
i pulled the carpet up again and filled the tank, half a litre at a time
eventually i saw it sweating around the fuel pump gasket
hope thats the only leek RR 2005 4.4 petrol
Post #584037 16th Feb 2021 3:36pm
knares
got my son to drive the car to day while i watched the fuel pump
it only leaks when fuel so being sloped around, like when it being driven
so its the pump out
cant remove the fuel pipes from the pump
watched a couple of videos and read some peoples reports on removing the fuel pipes
its frightening, big dollars, every thing gets damaged and has to be replaced
i have tried every thing i can think of RR 2005 4.4 petrol
Post #584562 20th Feb 2021 2:54pm
The part you are looking at in the top of the tank is the filter, the pump is in the bottom of the tank connected to the filter with a pipe and wiring.
The fuel pipe comes off very easily if you know how to do it, there will be an escape of fuel that needs to be shielded from the cars interior...
It is not really a DIY job to fix your issue, you have to have some experience or you could make it worse.
Has this been changed/taken apart recently as it is unlikely it would just start to leak on it's own....
The filter is supposed to be replaced each 100,000 miles so maybe it would be worth letting the dealer change the filter which should resolve the leak...
The filters are around £100 here...
It took me around 40 mins start to finish to do the job but I dare say the dealer will want a couple of hours labour...
Good luck... Thumbs Up Pete
Post #584564 20th Feb 2021 3:10pm
