![]() | Home > Technical (L322) > Red Restricted Performance |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Good luck... |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
So back from dealer EGR valve and egr temp sensor!!
It just needed a bit of loving then, you obviously didn't spend any money on it for Valentines day and it felt neglected...
Ok so gone out again and!!!! no codes |
Hopefully it's giving you a warning... see how it goes... then maybe you can do the jobs at your convenience... |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
It's almost certainly not he EGR sensor.
GGDR thanks it was the EGR valve as well as the temp sensor.
Jayk what is telling you the EGR needs doing?
| jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226
This sounds like the same thing that happened to my car. EGR failed due to being covered in oil because the oil cooler gaskets had not been fixed in time by the previous owner. Caused boost leak and in the end was not drivable at all.....
I had x2 cpdes 1 is the sensor which has been on ages and i read the thread on here so am not worried about it.
| t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114
If you was going to pay 1k for repairs but was also going to do the cooler your sel, so if your pretty handy with spanners save the 1k but a decent reader buy the cooler gaskets and see how you go with the egr using your new reader. |
| All times are GMT |
