Home > Maintenance & Mods (L322) > Heated and cooled seat filter location
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Just found out from an irate swimbo that her seat isn’t heating but it was earlier all lights on and you can hear a fan I was going to check it out and found out there is a filter that can become blocked could someone kindly tell me where they are located so I can rule that out any other checks I need to do before replacing the whole unit please let me know
Craig 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #583518 13th Feb 2021 10:18am
Baltic Blue
Their is a full section in the WM dedicated to seats, full of info.
Available free to download from the wiki.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #583522 13th Feb 2021 10:38am
Furnitureman
Thanks Mate I’m on site working so upto my kneck in it thanks for the info I will check it out , appreciate you taking the time to reply Thumbs Up 2012 Range Rover Westminster 4.4 TDV8
Post #583529 13th Feb 2021 10:58am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I don’t have it to hand, but if you do a quick search there is a whole thread about taking these apart and replacing the filter - apparently it’s possible without taking the seat out.
Good luck
Post #583590 13th Feb 2021 5:29pm
Fox889
There are two, one under the base & one hidden in the seat back.
The base one, just put your hand under the seat & feel for a 'jam jar' like plastic cover, unscrew & voila! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #583646 14th Feb 2021 9:41am
Furnitureman
Thanks for that info I’ll give it a go 2012 Range Rover Westminster 4.4 TDV8
Post #583649 14th Feb 2021 10:44am
Furnitureman
front or rear of the base 2012 Range Rover Westminster 4.4 TDV8
Post #583698 14th Feb 2021 6:52pm
Fox889
Front.
I think if you crouch down in the footwell & look under the base you’ll see the black round canister. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #583700 14th Feb 2021 7:07pm
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
I took mine out today to clean. Sadly the driver's seat fan isn't moving at all, and passenger only heats the back. £500 for both heaters. 2009 TDV8 3.6
Post #584078 16th Feb 2021 7:33pm
