![]() | Home > Technical (L322) > Fuel Pressure Regulation Valve |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
Would help if you updated your profile to which model/engine you have...
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
Part of the challenge is knowing what is broken and what is normal.
Lift pumps are common failures... |
‘Lift pump’? Are you referring to the suspension air compressor or something in the fuel system? |
Search diesel lift pump on here.... The suspension pump is usually referred to as the EAS pump, it doesn't actually lift anything it just fills a tank..!!..
Still struggling to find anything using that term. |
What's an appropriate fuel pressure when starting a healthy car?
https://www.fullfatrr.com/forum/topic35481.html? Pete
